Brief Description: Contouring the intake and vent lines
I used my DA to sand down all micro for the engine intake inlet. I don't think it can be considered a NACA anymore since I've had to change the shape so much. I then added a lump of micro over the vent lines which later will be turned into an airfoil to reduce drag. On another note I was able to find the COOLEST air filter for my setup. Check it out, FrozenCPU sells a 60mm SS filter for CPU fans and is Super thin. I'm also surpized at how restrictive it is for being so thin as I'm sure it will do a great job at keeping the air clean and will be a snap to clean or replace. The installation of the filter will be detailed in another log coming soon.
