I was able to remove the peel ply and lexan this morning and lay up the 1 ply of glass that finishes up this layup. I did the work first thing this morning so this evening the resin had cured just enough to allow me to remove the peel ply, knife trim, and sand the tabs to an almost finished contour. Tomorrow night after full cure I will get the tabs completely done and be ready to add filler that will smooth the transition from tab to wing. I can smell the primer already!
