Building Integrity
Date: 7-20-2014
Number of Hours: 7.00
Manual Reference: ch 22
Brief Description: Fuel Pump wires and Engine mount highways
With every wire connection, I recognize the extreme importance in attention to detail. These wires are being routed in cramped places that will NOT be fun to service, so doing it right the first time is critical. The good news, however, is that I find this wiring business to be a blast! Funny, because it was the one thing I was most intimidated by before I started and now I want to spend 12+ hrs a day doing it. LOVE IT! Clean paths, combed wires, and zip ties make a rookie job look semi-pro. The one thing I took serious note on was routing wires in a way that would offer NO chance of contact with the engines flywheel teeth. That would shred hours of work in about 2 seconds and cause multiple failures. Therefore, the Adel clamps are REALLY clamped down, and route all wires away from the flywheel. I will also be adding zip ties along the wire when everything is wires up, making sure it all stays nice and tight.
Ready to PUMP you up!
Adel clamps on Engine mount
Adel highway
