Building Integrity
Date:  7-18-2014
Manual Reference:  ch 22
Brief Description:  Nose gear wiring and ground wires begin
Now this is fun stuff I can really get into. I finally got my crimpers, strippers and hardware needed to start basic wiring and I'm having a blast! 3 zip ties over the nose gear backup battery to keep the battery and all wires from moving around. This is an area that will be covered up and a pain to service so I want everything clean and solid. I added color coded heat shrink and labels for power, ground, and monitoringl. The VPX Pro has a channel for running a wire to the backup battery for voltage monitoring. SUPER cool so that I will know if the battery goes bad BEFORE I'm in an emergency and count on it!
Next I was able to start running the ground wires to the firewall grounding buss that come from the 2 ignition coils as well as the fuel level probes. Again, every wire is labeled and organized left and right in an easy to understand fashion for future maintenance. Guess I better start making drawings as well...
Nose gear ready for power and ground connection
Fuel level probes and coils are grounded
