Building Integrity
Date:  3-30-2014
Manual Reference:  ch 22
Brief Description:  Landing light enclosure and BU Battery tray
I prepped the surrounding areas inside the nose, added a bead of Flox to the slighly hollowed out perimeter of the landing light enclosure and pressed it into place for cure. I will be adding a final layer of dry micro for smooth transition on both top and bottom prior to final paint.
I also performed a tug test on the Backup battery tray that I installed and with a good tug, I was able to pop it off. In flight I highly doubt this much force would ever be placed on this tab but I still didn't want to chance it. Instead I drilled 4 holes in the plate and base, filled with wet flox and added another bead above the original and screwed it into place. This will hold MUCH better.
BU Battery plate holes
in place for round 2
