Building Integrity
Date:  3-26-2014
Number of Hours:  6.00
Manual Reference:  ch 22
Brief Description:  Battery hardpoints and iLevil bracket
4 large self locking nuts buried in wet flox and will be the hardpoints for the battery bracket. I had to drill out the cavities a little in order to get the alignment right on as well as add a stick underneath as a shim for level. After cure I will remove the bracket and fill the area to level again.
Next on the list was deciding a location and mounting bracket for the iLevil Backup ADHRS. I REALLY want to keep all the pitot and static lines short and in the same location so I opted to locate it spanning between the nose gear housing and F22. I will be floxing the 2 long rails in place as level as I can, but I designed the ilevils bracket to contain washers under each of the 4 corner screws. This will allow fine tuning of the pitch and roll axis later if needed. The location of the bracket will show on the next log when it is installed.
battery bracket hardpoints curing
iLevil bracket
iLevil bracket
