I went and grabbed my ELT and held it up to where it will be installed inside the right baggage compartment and noticed that I will only have to run 2 small wires to the remote panel unit. I then figured it made more sense to add another small nylaflo tube underneath the right longeron to house the wire. Instead of waiting for epoxy to cure I used clamps and superglue to hold them in place until I can add a small corner wedge of filler over the top of them. This concludes all of the electrical conduit in the aircraft which means im 1 more step closer to installing those consoles!
