The micro joint was cured this morning and sanded down with 36 grit to prep for a strong mechanical bond. After prepping the area with acetone, I cut 3 tapering plies of BID to cover each sump and lapping onto the surrounding surfaces. No this is not in the plans. It's overkill, and just what I'm going for :)
