So my "micro" fuel leak fix was really stupid. Micro absorbs moisture and I knew that. DOH! I removed all the micro and went all the way down to the skin and replaced it with wet flox like I should have the first time. I've got the heat lamp on it for a good high temp cure as well. I'm tired of seeing blue coming out of this sump...
