Building Integrity
Date:  4-14-2014
Number of Hours:  1.00
Manual Reference:  ch 13
Brief Description:  Actuator cover trim and planning
with only 1 ply BID the cover is pretty weak and if I Install it with screws I'm sure vibration over time will open the holes and make for an annoying issue. So far I've trimmed it for an ok fit but if I'm going for a good seal than I will be adding 1 or 2 more plies BID as a LIP around the perimeter that will be used for mounting. More later
