Building Integrity
Date:  3-9-2013
Manual Reference:  ch 13
Brief Description:  Re-Attaching the nose piece
The underside of the nose piece will be a little difficult to paint after it's attached so I decided to paint the areas that won't be glassed. After 2 coats of primer and 1 thick coat of hammered black I ran a bead of dry micro along the exposed foam and placed the nose in position to cure. After cure, the nose will get glass inside and out.
