First the door and nose piece will put in place after sanding the forward battery bulkhead for a precise fit. Then the nose door was temporarily taped in place so I could sand the underside flush with the door in prep for the glass lip. The door was then removed and all 4 sides taped off and then put back in place again.The Nose piece was re-attached to verify final position before the glassing will begin. I didn't like the idea of using superglue to hold the door in place because it's a pain to get off. Tape should hold it fine during cure. If nothing else I'll put 4 small dabs of glue on the corners for safety measure. I went to pull out the last of my BID and found that I don't have enough for the job so I ordered 20 yards of it which will take me through the rest of the project. Until it arrives, the nose will have to wait...
