Building Integrity
Date:  8-15-2019
Number of Hours:  3.00
Manual Reference:  ch 25
Brief Description:  Sanding sanding sanding
The bottom of the left wing was blocked using 220grit to a virtually flawless contour then top cut with 320 before flipping the wing over to tackle the topside. The topside had already been blocked with 180 grit months ago when I rolled on the white, but she needed a fresh round of blocking to prep for final primer. I also tackled the wingroot section with wet micro where obvious low spots had developed. Tomorrow I should be able to block this down and have her ready for primer tomorrow.
220 block sanded
220 block sanded
220 blocked
220 blocked
Wet micro fill over low spots
