Building Integrity
Date:  3-8-2018
Number of Hours:  2.50
Manual Reference:  ch 25
Brief Description:  Pins and needles of perfection
I swear a guy could build an entire Vans RV in the time it takes to fill, finish, and finesse a long ez. Perfection is costly but oh so worth it. After opening the canopy gap up even more, I decided to install a temporary weather seal to verify fit, and it worked out perfectly. The seal "just" seals up when the canopy is locked down which means I can now final sand and prep for primer. The canopy to deck still needs a little build up on the deck side so instead of adding a thick layer of micro, I went with a trick that really helped me on my Roncz. I mixed up some slurry and spread it out on both surfaces like I would skim coating. This also filled a bazillion pin holes that I had opened up so It's a win win. This I "hope" will give me just enough build thickness to allow final contour before primer.
While the slurry was setting up, I removed the wheel pants and scuff sanded them for primer as well. I also prepped the nose hatch for primer as I see primer coming within the next 2 days for sure.
The spot filler that had been applied a couple days ago also got sanded down. This birdy is about to lose all it's grey and be completely white. lol. She's an old gal at heart.
temp seal for testing gap
a PERFECT gap seal
a PERFECT gap seal
pin holes galore
pin holes galore
