Brief Description: Final Micro and paint for the cooler plenum
After all the sanding of the Micro was finished, a much needed roung of Z-Grip took care of all the final low spots and pin holes. I then added 2 coats of black hammered brush on paint by Rustoleum on the exterior. I also decided I will be adding this paint to any areas on the firewall and spar that aren't covered in SS. Should start looking really nice. The interior of the plenum will most likely be getting a round of high build primer, sanded to 320 grit or higher for a nice smooth interior finished. First, airflow tests will need to show that a series of air vanes aren't cruicial. Otherwise, more work to be done :)
