Brief Description: Tips are close to being finished
These new tips are so gorgeous. I can't just throw em on the plane with pin holes and primer, I need them to shine. With several rounds of micro, skim coats, and primer, I was able to get the contour virtually identical and fitting the canard just right. After tonight aggressive sanding, I know I opened up some pin holes and will need to go over them again with wet micro. I even sprayed some paint on before closing up the shop as a guide coat for tomorrow when I really start fine tuning the contour in prep for final paint. These bad boys are taking 3 times longer than I expected and are totally worth it. Especially If I make molds with them and sell them as a carbon tip to other builders.
