Brief Description: Cowl micro and wheel pant primer
Lot's of forward movement today. I was easily able to sand down last nights micro on the cowling, brush on a thin layer of primer to expose pin holes, then slurry coat the surface filling EVERY pin hole in one shot, then sanding it all down to final contour. After a few touch ups, she'll be ready for paint. But first, I'll be carving out the carbon and foam that's underneath and finally getting to layup 1 ply of glass on all internals layups that have been patiently waiting. Man am I glad I am finally tackling this cowl/pipe clearance issue. no more burnt cowling and blistered paint! I was also able to add micro and sand to contour on the wheel pant mod then add a layer of primer. I've only got 1 pin hole that's showed up, so it will be a day of Z-grip and spray primer / paint for both the cowl and pant tomorrow!
