Brief Description: Wet sanding, micro and filler joy
I finally got around to wet sanding the other aileron today and found a delam that needed to be eliminated. Filled it with wet flox and will wait for cure before heading to the primer gun. I also cleaned up the other end of the canard and filled both ends with dry micro. I then went over the whole canard with Z-grip filling the damaged areas that were left by the vinyl removal process.
