First off, I rolled out a thick layer of wet slurry to seal the surface. After it tacked up, I spread a thick layer of wet micro all over. This should keep pin holes away and allow a nice surface to sand on. Before final contour I'll be spraying it black and setting it out in the sun to make sure it's post cured BEFORE it sees it's final shape. I'll be sanding using the canard template to ensure a good shape.
