The lovely 2" SS pipe that I got from UL will make a lovely joiner between the throttle body silicone and the 2" Ceet tubing. SS is not so easy to cut, but the dremel had that taken care of in about 20 minutes. Moving on, I added 2 more plies of carbon to the end of the outside plenum flange for a tighter fit on the CEET tubing but it turned out to be a little too thick. I sanded it down to a nice snug fit then added micro to the obvious voids. After this final round of micro it will be time for the hammered paint. Finally, I was able to spray 3 good coats of black primer on the lower cowling, exposing all the pin holes and voids. After it cured a bit I used left over micro to fill em in to cure overnight. May actually get this lower cowling totally finished within a couple days!
