After installing the Vortilons, they needed to be faired into the wings a lot better. I added 700lbs of Z-grip to each one :) I then added spot filler to the right wings, delams and may even need to add more if it proves later that the contour doesn't look good enough. It's a shame that I had to do this considering the hours I put in, to making these wings so perfect in contour. Finally I found a way to plug the top of the bottom skin next to the aileron where I damaged the skin installing the aileron. ugh. Instead of using flox or glass I tried adding some flox to the Z-Grip and MY GOSH, that stuff was a bear to sand! The good news is that the repair is flush and now awaits the lovely addition of primer.
