Brief Description: Micro in the nooks and crannies
The landing light lens was pressed into a small bead of micro. This should provide a definite transition. I also placed micro in a few areas that had major obvious low spots. I will most likely be spraying primer this weekend and will need this baby as prepped as prepped can be :)
I'm wonderfully ahead of schedule :) :)
Joe Coraggios best advise on finding any last pin holes in the fuselage... Go Around.
