Brief Description: Elevator spot filler and final primer
First of all I have finished the canard. Wet sanded to 3000 on both sides. DONE. Now I was able to find a million little crappy pin holes after the last blocking of the elevators. SO instead of blocking and filling I filled BEFORE sanding. After sanding it's much harder to find those pin holes so this worked great. I then blocked them down, prepped and put the final 3 coats of primer on these bad boys.
