The 3 plies Bid over the hidden rudder bellhorn worked great. Good and rigid. At this point I am now ready to add final filler and do the final skim coats. I've got my epoxy primer on it's way so I need to get the wing done, sprayed and hung back up. Filler was added to the lower winglet and rough contoured. Tomorrow spot filler in the obvious lows, then finesse everything with 80 grit and start skim coating. The Ailerons were mounted to look at how well the edges all lined up and a little more flox under the hinges will fill the gaps nicely. However that will be logged under a different chapter accordingly.
