Brief Description: Fill and Sand from firewall to nose
Today the canopy is on and it was time to bring the fuselage into 1 long streamline contour with filler. I added filler from the firewall to the nose and started sanding. At this point I'm convinced there is NO reason someone should go to the gym if they are building a composite airplane. I've brought the contour to a good general shape, but there are several low areas still. These spots will be filled and the sanding will continue later.
