Building Integrity
Date:  3-3-2013
Number of Hours:  1.00
Manual Reference:  ch 10
Brief Description:  Gone with the wind
So all my other projects have epoxy that's drying to I thought I'd try to solve a little drafty problem. Air gets in through the side of the fuselage where the torque tubes enter and exit. The Cozy Girlz have solved this problem with an updated version of the offsets however my canard does not have these. I am therefore going to attempt to close off the area as much as possible and it will start by closing the rear gap with flox. I Installed the canard and marked the full aft position of the torque tubes and laid up flox behind it. I plan on using a piece of medium density soft foam cut to fit the other gaps as well. we'll see....
