Building Integrity
Date:  6-7-2012
Number of Hours:  0.75
Manual Reference:  ch 10
Brief Description:  Glassing the upper wing tip
After making sure the upper contour was good enough, I slurried the foam and added 2 ply BID to the upper wing tip. I did this WHEN I did because the underside glass was still a bit tacky and I wanted the upper and lower to be sealed together at the edges without having to sand between layups.
nice curves :)
nice curves :)
final layup
final layup
