Brief Description: Pilot and Passenger power panels
The pilot will have headset jacks located behind the left arm on a plate held on by 4, 4-40 screws. Likewise, the passenger has a power panel that includes heated seat controls and dual USB charging ports. Because these panels will be "utility" in that they get a lot of pushing and pulling, the standard RTV silicone idea may not be enough. Instead I've added 4, 4-40 screws to each panel. I installed 4 nuts into recessed areas using 5 minute flox and then filler. This should hold things much better in the long term.
