The Floor is routed out per plans however this is right where my fuel pumps are going to be installed and I would rather not build up tall standoffs to mount them on so I filled the floor with foam in an earlier post, then added micro to fill voids and laid up 2 plies BID and Peel ply. Later, hardpoints will be floxed in place for mounting the fuel pump bracket.
