Brief Description: Main wire harness access in passenger consoles
The passenger thigh support acts as a housing for the Vertical Power VPX pro that was discussed in an earlier entry. Here is where ALL the wires in the aircraft will lead INTO and OUT so I had to cut access holes in both rear consoles to make this work. The cut line is 1" less in dimension than the outside dimensions of the support so the hole will not be seen when the support is installed.
