Brief Description: Sanding off peel ply and passenger support fill
The previous owner had left peel ply on the areas where the strakes and spar would be glassed, in order to avoid sanding. Unfortunately He never got around to that step so the peel ply was left on and REALLY hardened into the epoxy. I spent hours trying to remove it but with no luck, so being precautious I sanded it down to the glass as best I could without going through the glass underneath or on eather side. 80 grit worked great and it took about 1.5hrs to get it to this point with the powered hand sander.> With the left over dry micro I filled the joint lines in the passenger thigh support in prep for its glass work.
