I'm pretty sure I'm the first pilot to install a tail beacon ADSB2020 unit into the nose of an airplane. Of all the choices I had to pick from to bring this bird into 2020 legally, I ended up choosing the tail beacon by uAvionics. This beacon is by far the EASIEST solution there is to date. Power, Ground, and DONE. The unit only costs $1650 and literally needs nothing but a power and ground source. It has a built in WAAS GPS and ADSB antenna. Not to mention the user configurable "stealth mode" or Anonymous mode if you will. Yep, when squawking 1200 I don't want anyone knowing who I am or what my intentions are. I fly to leave earth's inhabitants for some R&R. I don't even file flight following. Those clouds are my therapist and I like alone time when I'm in counseling :) The good news, is that this mod is all 100% legal and only required a small mounting hole drilled into my F7 Bulkhead. Win all the way and a zero drag mod.
