From day one, the iLevil AW has been having issues cutting in and out in use. Not ok when depending on it for emergency efis functions. I removed the canard and removed the unit to ship back to iLevil for a fix or replacement. While the canard was off I gave it a good inspection and also replaced the light grey weather seal with more fitting black and sized for the gaps being filled. I also slightly adjusted the elevators to fair more evenly with the canard tips. This will help in rigging the aircraft to fly straight as well. Not sure how long till I get the iLevil back but the airplane is grounded till then. More "time" to get other things done.
