Building Integrity
Date:  9-23-2014
Number of Hours:  1.00
Manual Reference:  ch 22
Brief Description:  Nav/Stobe light install
This was a cool job to finish. I lined up the lights to level at cruise which is about 2 degrees down from level with the longerons. This way the lights will be only create a very small amount of drag. Instead of installing 4-40 nuts and screws, I decided that being totally weather tight was more important especially considering that LED lights will outlast the airplane and may NEVER need to be replaced. However, When it comes time to paint, I will simply run a razor blade under the light for removal.
Level with longerons
Light 2 degrees down
Testing out the lights :)
