Building Integrity
Date:  8-28-2014
Number of Hours:  8.00
Manual Reference:  ch 22
Brief Description:  More adels and panel assembly
I did 8 hours today but it felt like I should have got more done. I started by assembling the passenger power panel and adding weather stripping for a better all around seal. The USB charging port and Heated seat controls were installed and now I am waiting on the audio jacks and plugs which will come Sat. I repeated this process for the pilot panel as well. A little PIA that happened was a couple nuts pulled out from the hard point locations and needed to be bonded back in place. They are now fixed and ready for final mounting.
I next decided to butt splice the Nose gear power and ground and route the wires using adels. I then added adels for a path to the landing light, however this needs Molex plugs so it will have to wait till Sat. for completion.
Passenger power panel
weather stripping
weather stripping
pilot headset panel
pilot headset panel
