The engine compartment is getting REALLY tight. I am being very careful to route wires in such a way that no rubbing occurs anywhere. First, I ran a 14awg wire from the starter switch to the starter. I then I took time to zip tie things up a little tighter as well as install an adel for the AP servo wires. I then changed gears and headed up to the panel. I went ahead and started wiring up the "ENGINE" section of the panel switches which by far is the most difficult due to the 22awg wire that is used on 2 of them. It took WAY too long to do this compared to how Fast Harrison Avionics could do it, but I have a lot of time to kill so I thought I'd help them out :) My gosh I'm amazed that my simple little VFR Panel has enough wires to run a football stadium. Crazy and I'm glad I didn't try to do this on my own!
