Brief Description: Aligning the magnetometer brackets
learning a lesson from the elevators I won't trust the iphone's ability to measure angles correctly ever again. And more tests of 2 different level apps proved the iphone to be a joke. Instead I spent 2 very annoying hours cramped in the back seat finding the centerline and using it to make practical reference lines to use for aligning the magnetometer brackets. This took a lot of time and wasn't fun, but I'm glad I chose the strake location. I will later be building a false wall that will protect it from damage. Finally after getting the angle as close to 0 degrees in every angle I superglue tacked it into position, then made some flox and embedded it around each of the 3 legs. After cure, I'll remove the aluminum bracket from the legs in prep for paint. :) Coming SOON!!!!
