Building Integrity
Date:  2-18-2014
Number of Hours:  1.00
Manual Reference:  ch 22
Brief Description:  Transponder antenna
I've elected for antennas that will NOT be located outside of the aircraft. These new antennas are able to be bonded to the fuselage tucked away from site. Here I've installed the antenna at a 45 degree angle according to the manual and is set up in wet micro to cure overnight.
trans antenna
trans antenna
