Building Integrity
Date:  3-10-2016
Number of Hours:  3.00
Manual Reference:  ch 21
Brief Description:  The never ending fuel leak
So Apparently my post curing mistake made things a lot worse than I thought. After sending fuel to the right tank yesterday, it's been slowing leaking out behind the SS firewal and down the belly of the plane. GEEZ! I had to remove half of my hardware to pull the firewall and verify the leak location. This is craziness. Tomorrow I'm going to have to spend the day grinding away around the sump and PINPOINTING the leak(s). I won't stop this time until ALL leaks are found and fixed. All other jobs are on hold till then.
puddle of 100LL
puddle of 100LL
lower hardware removed
fuel exiting here
fuel exiting here
