The foam and glass schedules for the right strake are identical to the left however there are 2 things I did differently. First I filled the strake/wing joint with a thin foam wedge instead of using a sectional as I learned it's a little quicker. I also didn't have a fuel return line on this strake so instead of having 1 hump on the left, I made a template of the left side and create an identical foam "Hump" if you will, on the right. This of course is cosmetic only. 1 ply Bid tape all around.
