took an hour to remove the bolts and separate the wings from the strakes. It was crazy but after the bolts were removed, the wing stayed attached because of the thin layer of Flocro in the seam. Took some shaking to break the seal. Temps were around 45 degrees in the garage which makes removing sticky tape residue a real pain so clean up will have to wait for a warmer day.
