I cut and bent the fuel return line that is now awaiting B-nuts and a bulhead fitting. I also installed my passengers fresh air naca inlet in a bed of dry micro. Finally I added 2 plies BID to the rear spar/strake intersection and 1 ply BID to the fuel line bulkhead fittings per plans. enough said.
