Now that the flox Bead has fully cured over 3 days time, I took my DA sander and knocked down all the rough edges. I then took several sanding block shapes and a file and smoothed the edges. Finally I used a scotchbrite pad to scuff the entire inner tank surface in prep for it's final skim coat. 3 hours and I won't say the inside of the strakes look anywhere near as nice as some I've seen, but with no loose ends it will be just as structural and functional as the pretty ones. Most importantly, leak free. This weekend will be, fuel probe location, fuel cap installation and underside BID tape application in prep for the sump blister install.
