Building Integrity
Date:  3-12-2013
Number of Hours:  2.50
Manual Reference:  ch 18
Brief Description:  Cam Lock Pin holes drilled
The canopy is held in place by 2 pins that pass through the longerons and into the cams. The holes were drilled slightly larger than the pin head and tested out great. I'm looking forward to finishing this new canopy design!
I also took time to polish the inside of the tubes and sand them flush with the body.
sanded and polished
sanded and polished
cam in locked position (closed)
Pin installed in closed position
