Building Integrity
Date:  1-13-2013
Number of Hours:  4.00
Manual Reference:  ch 15
Brief Description:  Jury is in...
The Jury is in and the plans win the draw. I'll be using the bellcrack according to Rutans plans for 2 reasons. 1, it allows the cable to clear the pushrods, and 2 it saves the cable for having to turn almost 100 degrees. That's a no no. The bellcrank holes were marked, drilled and test fit. Everything was spot on but I thought the rudder cable came a little too close the the fuselage sides at the firewall, so I carved an angled groove to accomidate. This groove will be re-glassed before final install. testing the cable routing proved to be successful with no binding angles or interference.
Bellcrack allowing clearances
Bellcracks Mounted
Bellcracks Mounted
Cable routing hole
Cable routing hole
