Brief Description: Trial fitting the firewall bulkhead
When i purchased this project the firewall bulkhead was cut out but not installed. After deciding to trial fit it to the longerons I noticed a little warp in the longerons that wouldl make it impossible to install unless I leave it on while mounting the gear and spar. This must have been how the original builder did it: Mounted the firewall bulkhead, THEN constructed the gear mounts. Smart in my opinion, but i'm sure glad I saw this when I did. At this time it will remain on the fuse but not glued in place until gear and spar will be perminently installed.
