I took a closer look at the trailing edges of the main gear fairings and found that they needed a good trimming in order to flow into the fuselage without extending past the firewall. While sanding the upper halves of the TE came apart JUST like I thought they would. That's why I whipped up Flocro instead of Micro this time. I clamped them up to a matching position with a generous amount of Flocro inside to ensure a better bond. I then spread the flocro over the fairings where they intersected each other and down onto the skirts as well.
