I cut off the end of a funnel I had in the garage and taped it to the exit of the pee tube. I found that this offers the best suction so far so I'm going to start with this as a base. However, I will be locating the exit of the funnel at the AFT edge of the pant leg instead of protruding out like in the pic. This will make it much easier to get the affect but without the ugly tail. I may also use a larger funnel up front in case I REALLY need to go :)
I was able to test it out with a 1 hour flight today :) 6 to go!
