Building Integrity
Date:  9-7-2019
Number of Hours:  3.00
Manual Reference:  ch 25
Brief Description:  Control surfaces get primer
The ailerons and rudders needed a fresh coat of primer after block sanding and boy do they look amazing. This new white primer will be sanded to 350 grit like the rest of the bird and they will be ready for install on monday unless I make a mistake and blow through the primer.
Fresh primer for the control surfaces
