The right wing is now getting a lot of needed attention. The lower side had 3 delams to repair and heat expansion created the need for re-contouring with micro in the low spots. All these were addressed before block sanding and spraying 2 coats of primer. The leading edge of the wingroot was also damaged by the "Jet Guys" when I went to visit and inquire about rigging. Their "hack" type of getting the job done was rediculous and now causing me to repair the area. No worries though, as a little micro goes a long way.
